Do gearboxes from pre-crossflows and crossflows interchange?
The reason I ask is that I am looking at buying a supra 5 speed that was on an iron head 4.1 crossflow, using the dellow bellhousing. (in a te cortina)
I want to know if that box, using that same bellhousing, will fit my precrossflow 250, currently auto, tc cortina?
And will the pedal box from that te fit in my tc as well?
Will everything just bolt on?
All sixes between 1967 and 1988 have same bellhousing pattern, so it ought to bolt up.
cant help with cluch arrangements as the falcon and cortina are different, Earlier falcons have hydraulic clutches later including corty have cables
A7M
In the case of the later Three-speed, a late 1978-on wards one won't fit the early alloy bellhousing and hydraulic clutch. You have to swap the gearbox and bellhousing with putting a newer X-flow engine and gearbox into and early XR to XC.
Clutches vary from 9.125 to 9.25, 9.5 or biggier in the 250 cube F150 trucks.
1966: XR Falcon 170 and 200 engines run the same bellhousing pattern as the last Nissan Ute/Ford Falcon XF utilities in March 1993. Location dowels and bolts are all the same.
1971: The 200 and 250 sixes got a V8-style crank flange, with six bolts at 3" centres. Before that, the cranks had a 2.75" pitch six bolt flange.
From 1971, an early 66 to 69 170-188-200-221 flexplate or flywheel won't fit a post 1971 200/250.
1972:Cortina Sixes created the need for a cable clutch in 1972, but Falcons stayed hydraulic till mid model range (1978) in the XC.
Falcons remained cable from 1979 to date.
There are Toploader, T5, and Borg Warner single rail bellhousings, and 3-speed bell housings. BW 35/40 AUTO and C4 are cast iron.
All hydraulic clutches are left entry. The cables vary. Single rails have right entry, then go to left entry with the T5 in the XF.
Separator plates thickness varies. Early manuals have thick plate, later autos are thiner.
Starters are common, and all flywheels and flexplates are 160 teeth. Interchange between 1971 to later x-flow gearboxes is total.
Thanks for the info xtaxi.
So do you think I'll have any problems getting that supra box (as mentioned in first post) into my tc?
xtaxi":14a6ihlp said:
It won't be a problem. The crossflow /dellow/supra combo will be fine.
Thats great news as I didnt want to get rid of my pre-crossflow just yet. It seems to be running well so I'll keep it until it breaks. Should be a whole lot more fun with a supra 5 speed behind it compared to the old 3 speed auto!
Thank You.
