I'm planning on doing some bottom end work on a bone-stock 200. The main purpose is to replace a badly leaking rear main seal, but I think I am also going to have the crankshaft machined (or install a crank kit) to correct slowly declining oil pressure. The engine has about 120k since it's last rebuild. this is a daily driver and I will probably always keep it near stock.
My question: What fasteners do I need to replace? Rod bolts? bearing cap bolts? The oil pump will be replaced, too. Does the pickup tube or oil pump drive shaft need to be replaced?
I plan on doing this while the engine is still in the car. Other than a comfort factor, does anyone see issues with doing this?
thanks,
Kevin
thanks,
Kevin
