Ok Guys, I know this topic has become tedious, but I'm seeking some resolution.....Tonight I rechecked the old and new shafts....and I DId finally spot the milled flat along the bottom edge. This seems like it would help lube the arm on the shaft better, and maybe even force out more oil on the valve stem side. Makes sense that you wouldn't use a pedestal drain with this....HOWEVER, I found the 'flat' shaft on the old '65 set, and the 'new/rebuilt' shaft is perfectly round, no flat! So who knows...maybe the old shaft had been replaced at some point--maybe the new shaft was not milled for some strange reason...who knows. Now, I'm leaning toward using the old shaft with flat bottom, put the new arms on it, and eliminating the drain pedestal!
