i got my rebuilt 200 back in this weekend. i was going to put the driveline back on the C4 tranny, but the instructions call for some special lubricant to be used on the shaft. i was going to just use transmission assembly lube thinking that the ATF lubed that part but i found out that was not the case. both the shop manual and the Haynes manual just give ford part number for the lube. what type of lube should i use for this?
thanks.
-evren
thanks.
-evren
