DSII sticky down?
TucsonHooligan
I need info on the DSII conversion, but the links in the sticky section aren't working. I can load the module diagram, but I can't get the pics to load, it goes to a dead link. Anybody have another link? Or is it working for anybody else? All i need to know really is which wire I should splice the "12v switched bypass wire" into, as seen in this diagram:
http://my67mustang.synthasite.com/gm-module.php
I have done everything else, clipped pink resistor, disconnected brown cranking wire from the solenoid terminal, etc., I just need to know for sure which power wire to tap into to feed the coil. Anybody help with this?
Any 12v switched, best way is to use the connection on back of ignition switch you took resistor wire off of. I take it you are using the GM module.
