to revherbal and others concerning your posts. I never received any notification I had responses(preferences set)on my post. Also, the administrator will not allow me to post a PM. Not sure why all the secrecy on this site. I did finish the 6=8 mod with the weber 38/38 DGAS 2bbl. When putting it on, the log head has to be removed and water hoses re-routed. I opted to do the easy dual advanced distributor with points. Engine was running fine until recently when it started dying of fuel starvation. Finally contacted Larry at cliffordperformance.net and went through all the steps. He asked what fuel i used and i said no-ethanol. The carb float was set for ethanol fuel. Also, the fuel pressure module that was part of the kit did not come with a gauge, so i go to local auto parts store and put one on. Wrong! He said those are not compatible with the unit. He said set the pressure at 3psi and remove the gauge. So, I did all that and still have a half tank of no-ethanol fuel. Now car has a miss. Set timing by engine sound and still has a miss. Should have done the DS II distributor upgrade. Still troubleshooting the miss. Got a timing light coming from ebay.
