First, I dug out my 67 shop manual and the gasket wasn't shown in that diagram. The illustrations I posted were out of the Master Parts Catalog, so maybe the gasket was an optional part? Who knows.... As for them not mentioning the gasket, I don't think they mention the o-ring either? The other thing that puzzles me, if they never leaked, why did Ford make a gasket? Could it be that it was an optional part, and only installed if and when it was needed, during routine service?
Next, it still seems to me that if a gasket fixes the problem and doesn't adversely effect the end-play, then it's a viable solution. However, the only way anyone is going to accept this as a solution, is if I can prove that it doesn't. Correct? Therefore my statement was meant to be factual, rather than sarcastic. Sorry it came across that way, I guess it's just how you interpret it.
Performance Distributor is looking into the problem. Could be it needs a larger o-ring, or it may be beneficial to add a second o-ring. They are also going to verify the size of the groove, to see if any adjustments are needed there. And they have agreed to see what they can do about making a better clamp. I think some of the first units included a clamp, but it was only for a short time.
Whatever they come up with, I'm quite certain they will work with anyone that is having an issue. The gasket just seems to be the quickest and easiest fix for the moment, even if it's only temporary, or until another solution can be found. Unfortunately some guys on this forum are quick to jump to conclusions, and a few derogatory statements were made, which I deleted. I just think we need to give them an opportunity to fix the problem, rather than criticize them. You can't fix a problem if you don't know about it. I've been selling the DUI for three years, yet this is the first time it's been mentioned, therefore I think we should cut them a little slack and give them a few weeks to work it out.
