Okay, to start off, this is in a 66 Mustang 200. I bypassed the ballast resistor, and wired up the distributor. I got it running and set initial advance to 12*. I then hooked up the vacuum advance to ported vacuum.
The problem is, the engine is running extremely rough, making a nifty throbbing noise at idle, that is shaking the entire car. Also, when I hit the gas in neutral, the engine almost dies on me. And, if I hit the gas too had too quickly, it backfires out of the carburetor.
It seems to do it a little less when I have the vacuum advance hooked up, but it is insignificant enough of a change that it may be purely psychological.
So, what could be causing this? Could it be something in the distributor? Even though it's new? Is there a way I can test it?
Thanks, this has me stumped.
-Chris
-Chris
