Howdy All:
I realize that the DUI system parade is well under way, led by very enthusiastic cheer leaders, but- for the record-
*All ignition systems will do better when kept in top tune. All engines will run more efficiently with a little more initial advance then stock specs call for and tuned for your total engine package.
*No, your Autolite 1100, with a SCV, will not send a correct vacuum signal to either a DS II or a DUI system. They both require a ported vacuum signal. If you have a performance cam with lowered engine vacuum, you can try a full manifold vacuum source to either of the better distributor systems. Autolite 1100s after '67 do not have a SCV, but do have a ported vacuum port.
*The DUI system does not have a multi-spark discharge as with an MSD6A unit. An MSD unit is not necessary to use an DuraSpark II system. The MSD 6A unit can be added to either for a multi-spark feature.
*The DUI system is contained. The coil and module are on or inside the distributor cap, for a much cleaner underhood appearance. THe DUI distributor is physically quite a bit larger than a DS II.
*Both have vacuum and centrifugal advance built in. Both are very reliable. Both offer a significant improvement over a Load-a-Matic or point type distributor.
*Recycled DS II systems are quite a bit cheaper and very reliable.
The bottom line is- maintain what you've got, tune to get the most out of it.
Some folks prefer Dolly, some prefer Paris. Your choice. Which ever way you go, enjoy it.
Just remember-A day without sunshine is like...night.
