You can get it from Jegs, but you'll have to do a search for the part number above. You don't really need this, any two wire plug will do, but this makes it very easy. The Duraspark box is no longer used with this connection.
I used the connection that came in the box with 2 spade connectors and slide the spade's over the the connectors in the wiring module coming from the distributor. I used some dielectric grease on the connection and a little RTV to seal in all up. Seems to be working fine so far but I've not encountered any wet weather yet.
