8) since our engines are carbed, we can make a few mods to run E85 or straight alcohol. flex fuel is tougher though with carbs. if we set a carb up to run E85, then the engine runs too rich on gasoline. it can be done, but tuning is going to be somewhat of a nightmare. if you switch to EFI then making a flex fuel engine is much easier. you just need the right sensors, specifically the right O2 sensor, and programming. you also need injectors designed to run alcohol.
