If you pick a cam that lopes , YOU WONT like the way it runs , unless you spring for the converter change .
			FalconSedanDelivery":oeqhkjb1 said:If you pick a cam that lopes , YOU WONT like the way it runs , unless you spring for the converter change .
Thanks FalconSedanDelivery
FalconSedanDelivery":1fvgy22z said:If you pick a cam that lopes , YOU WONT like the way it runs , unless you spring for the converter change .
ClasicInlines":2v3ve79u said:Isky Racing Cams - USA
Hydraulic Lifter Cams
248: 248/248 - 194/194 - .415/.415 - 109* - 1000-3800
256: 256/256 - 202/202 - .450/.450 - 112* - 1500-4800
echo1955":2rxo5d7g said:I will let my grandson deal with the trans, rear-end disk breaks should he take the interest when his time comes..
He’s only 8 now..
No , You have the converter that has the ring gear on it , some companies will CUSTOM build one , BUT it will be over 600.00, Stay mild with the cam and a112 at min lobe center , if you would build a 250 , then yes that converter would workecho1955":2481fpt3 said:FalconSedanDelivery":2481fpt3 said:If you pick a cam that lopes , YOU WONT like the way it runs , unless you spring for the converter change .
I found this converter. Will it work.
http://racetransmissions.com/store/prod ... ts_id/1104
JackFish":3457c60b said:Do you have a low-mount starter?
The high mount starter uses a variation of the C4 that has the ring gear welded on to the torque converter.
Not sure if what you're looking at would work.
Again, if you're using an automatic transmission you don't want a rough idle cam. They don't make enough vacuum, AFAIK. the 112° LC cam is recommended for an automatic for that very reason, and although it does have a bit of a lope below 1000rpm I can't say for sure that in my case it's due to the cam, and not something else. BTW I am running the 264/274/112° cam. You might look at the 268/274 from Classic Inlines, it's just one step up.
	MPGmustang":2rzvw1r9 said:ClasicInlines":2rzvw1r9 said:Isky Racing Cams - USA
the 256 is stock diration, BUT the lift is not! it's the desired lift, this should give more low end like your looking for, and your roller rockers should come in a 1.65 ratio makeing the power band come 500rpm sooner, so the 256 would look like
256: 256/256 - 202/202 - .495/.495 - 112* - 1000-4800
It's the only one I found with a 112* lobe center. should make plenty of vacuum!
FalconSedanDelivery":15cyjiop said:No , You have the converter that has the ring gear on it , some companies will CUSTOM build one , BUT it will be over 600.00, Stay mild with the cam and a112 at min lobe center , if you would build a 250 , then yes that converter would workecho1955":15cyjiop said:FalconSedanDelivery":15cyjiop said:If you pick a cam that lopes , YOU WONT like the way it runs , unless you spring for the converter change .
	MPGmustang":3m108q87 said:echo1955":3m108q87 said:I will let my grandson deal with the trans, rear-end disk breaks should he take the interest when his time comes..
He’s only 8 now..
I can be your grand son while u wait...![]()
	bubba22349":b65wkf1t said:You could swap in a later model C4 and gain the better shifting valve body, and stronger input shaft too. It would be mostly a bolt in only real visible exterior change to car would be a 1967 or up shifter. Add a shift kit and could handle the mods you wanted to do.
FalconSedanDelivery":suqewx51 said:Unfortunately , Changing the year of the trans WON"T help with the expensive converter deal , only if you had a late low mount 200 or a 250 would it get cheaper,the reg 144-200 use the same Converter / flexplate deal ,
the 70.5 models being the best C-4's but they to still use the same style as you already have
