Curseoftheblade
Active member
Hey all,
I have a 66 Mustang that i dropped a 250 in (from 1975). I've been having trouble with the duraspark II ignition and was thinking to just swap to points. Will a 200 distributor with points fit? As in, is it the same size as far as the 250 electronic distributor? In whichcase, would i be able to pull out a points distributor from a 200 i have laying around and put that into the 250? If that doesn't work, would i be able to swap in an earlier year 250 distributor with points? ie: 1972
Thanks a bunch!
Connor
Thanks a bunch!
Connor
