Electric Fuel Pump Ifo Needed
kukm66
I guess I will go with an electric fuel pump on the 64 Ranchero and need some info:
What brand and model type of pump did you use?
Need exact locations to hook up 2 wire leads
Several brands most parts store carry, need something about 6 psi- 8 max. Power wire goes to run side of ignition switch.Turn switch on you will hear pump run and load up, then turn to start position. Ground wire can be grounded any where close to pump installation. Install pump in fuel line exiting tank as close as possible to and below bottom of tank, try for a protected area. Electric pumps work better pushing than pulling.
