mysavioreigns
Got a couple more questions. I will be putting the engine and trans together tomorrow, and might be putting it in. We'll see.
I ran into a couple of problems though:
My DSII dizzy was too fat to fit down in the hole. I have taken off some of the material, and it will slide down in there, but I'm not sure how far. Is the O-ring supposed to be visible, or down inside the block?
I tried to take the fan off, and I removed the 4 bolts, but it still won't come off. I tugged and tugged, but nothing. Am I missing something?
I temporarily solved the problem with my carburetor (5200). I modified the TRD-2025 from Summit by using bigger slots for the wider bolt pattern of the 1970 head. The couple problems I'm having is, 1) it's not parallel to the front, and 2) the original stock linkage won't work.
So, I bought a cable linkage from a Maverick or something. That didn't work out as well as I had hoped, because the pedal was ridiculously hard to get to line up on the firewall and still move. I think I'll just fab something up out of the original, unless you guys have any other options. I'll still somehow incorporate the cable linkage as well.
