62goldenrodvan
Can anybody tell me what year 200ci will bolt in my 62 falcon van
:It has a 170 now, It also has a three on the tree that I want to keep,the bell housing is real small, I need to be schooled on the sixes.
any pre 1980 will work ( EO casting is 1980 up ).62goldenrodvan":wotz654r said:Can anybody tell me what year 200ci will bolt in my 62 falcon van:It has a 170 now, It also has a three on the tree that I want to keep,the bell housing is real small, I need to be schooled on the sixes.
62goldenrodvan":3m6pxbr4 said:matt1967,
Thanks,
So all pre 1980 200ci bell housings have the same bolt pattern.
61Futura":mgsajq0n said:62goldenrodvan":mgsajq0n said:matt1967,
Thanks,
No, but when the bellhousing was made larger, the engine block was made capable of bolting up to both patterns. I forget the year dual pattern blocks were made, but I remember reading that you could still bolt up the smaller bellhousing to the newer block.
Wilhelmus":3dq30nap said:As I said in your other post, I have a bunch of 200s laying around. One is a block that's totally stripped, already been tanked/fluxed, no cracks. I have all the pistons, crank, everything. Also fuel pump/trimmings/etc. I'm up here in orange county, and I'll give it all to you for 40$. More than it cost for me to get it, and have it checked. The ridge isn't so bad. I think it's 20 over as of now. I'll PM you my number.
Wilhelmus":28atr24z said:The one that I have to give right now is in a perfect condition to put bearings and rings, quick hone it, and put 100k on it easy. It'd be a day's work to assemble it and get the old engine out, and another day to swing the new one in. =D Let me know.
