So you guys were right on the coil wire. I hooked it up, changed that starter, and after charging the battery, it fired right the hell up. It ran like crap, though. After letting it idle like crap, I decided to give it some gas. The oil pressure was good. It made a his, went to die, picked it self up, then VROOOM. Then stumble, vroooom, stumble stumble stumble, VROOM, always hissing around the stumbling. Then it quit stumbling all together, and ran like a top. I tuned it down, drove it around the block, came back, and parked it. It was a great ride. Then I pulled her in, looked at the temp, it was right on, the engine was nice and warm, everything was pretty spot on. I went to fire it back up. Stumble stumble stumble hiss. Then it squeaked, the oil light came on, and a puff of smoke came out from under the hood. I started it back up, and it ran good again. I let it idle, and it started to stumble, then it would pick up. Every time I give it gas, it'll stumble, but if I hold it, it will catch itself and idle good. Every time it stumbles, the timing light stops flashing. Vacuum leak? I'm happy that I got it this far. Also, the dwell is perfect, and stays in one place constantly, until I shut it off or it stalls, and then the needle shoots up, and then back down to zero. I have full voltage at the coil. The battery is charged up perfectly. Alternator was happy to be puttin' out power. What am I lookin' for now? I also hear a sort of ticking, or like two things rubbing against each other. What was that puff of smoke about when the oil light came on and it went POOF? I hope I don't have to cart it off somewhere, but at least now I can drive it up onto the dolly. =D Thanks again for all your help, I'm getting closer every day. =D (When it idled perfectly, my GOD did it have great power. I haven't felt it go like that for a long time.)
