well i finally got pissed off with the falcon not running properly . Ever since
i had the problem with the dizzy drive i had a feeling i wasnt getting the full performance from my engine ,the bits i have in it i just thought it should go better.Anyway i ripped it the head off for a start ,as i suspected
its all choked up with carbon ,not bad for 150km driving :x .The bores look good with all crosshatching still evident ,the tops of the pistons were
easily cleaned with a rag and some petrol .I checked all the lifters and they still look like they came out of the box .This brings me to the camshaft that looks goods from what i can see ,but that comes out in the weekend .Checking the wear on the cam drive ,on rocking the engine you
can get about 5-10 degrees of movement of the crank without seeing the rotor arm moving .So my conclusion is that the cam gear has worn that much the timing is wayout or maybee the timing chain has stretched hence making the valve timing late ........=rich black mess .What do you fine gentlemen think from this basic diagnostic dillema.
i also had a problem of it wanting to pink alot ,it was running 98 octane ,but i think it had a dose of 96 at some stage.It runs about 10.5:1
comp ratio ,do you think that would have contributed to the BLACK MESS!!
cheers dave
cheers dave
