Goldie
Hello everyone. Many of you have been following our build. Eng, trans, and suspension all upgraded. We are concerned with the excessive clatter coming from the valve train. I’ve read a lot about roller rockers being on the noisy side, but don’t know if this is our issue or not. Open to anyone’s suggestions or possible ideas. This is a high perf 200 with cast Aussie head, 2bbl Holley, perf Clay Smith cam, 10:1 comp pistons, header, balanced, 2500 stall conv in rebuilt C4.
Will remove the valve cover again to check clearances. Already checked the lash on the yella terra roller rockers and all good there.
Let us know what you think. Thank you!
