As a veteran of many snapped bolts (I'm a lousy mechanic), I go with the progressive drill, then tap scenario. The only way I've found to free 'em up in the first place is lube it well, let it set, lube it some more. Then, very slowly, carefully, and methodically....Turn it right, turn it left, turn it right, turn it left, in progressive increments. Patience and persistence and easy on the torque. You won't think you're getting anywhere to start with but I'm surprised at what I can get loose. Also, in general, an air impact works better than a ratchet and a grunt. A friend and I twisted off his shock bolts this weekend on the first twist.
