barishiman
Ok, so I'm having a problem with the studs that came on my Flamethrower II coil. I had to put on a new end on the ignition wire to hook up to the coil. When I put the ignition wire and dizzy wire (from Pertronix II) I can hardly get the nut to stay on the stud. If anything moves, like the wires, the nut comes off. The stud has a nut on it already with a washer beneath it. Is it possible I can take the nut off, keep the washer on and then screw down both wires so the nut will stay on while driving?
