Topic 5: Distributor Installation And Setting The Timing
If you are installing a DUI distributor into an engine that has an ignition system presently, then this simple procedure will have your engine running in no time. On the old distributor, remove the distributor cap and the vacuum advance hose. Note the position of the rotor. We suggest cranking the engine over until the rotor faces the firewall and mark it with chalk. Remove the distributor hold-down clamp and bolt. Pull the distributor up and out of the engine noting the postion of the rotor as the distributor clears the engine. With the cap off of the new DUI distributor, position the rotor to where it was when the distributor was just removed from the engine. Slide the distributor down into the engine. Be sure the rotor turns back to the original position (mark on firewall). If the oil pump drive does not engage, check that the rotor is pointing in the correct direction. If not, repeat the installation procedure. If it still doesn't engage, bump the engine over until the distributor drive drops into the oil pump drive. Reinstall the hold-down clamp and bolt finger tight. Install the distributor cap and transfer the plug wires. It is recommended to open the plug gaps up to .055" and this would be a good time to change them.
We recommend setting your initial timing at 12 degrees BTDC while the engine is idleing very slow (+ or - 600 RPM) and with the vacuum advance disconnected
