This is my first post here so I apologize if this has been discussed before. I looked and I couldn't find anything.
Anyway . . . What are your thoughts about using a rope or a rubber rear main seal on a Ford 200?
I'm rebuilding the 200 out of my 1966 Mustang convertible. I've put the rope seal in the block and the bearing cap twice now and each time when I torque the bolts down it makes it so tight that the crank will barely turn. I can tell that that cap is not sitting totally flat against the block and is causing a bind on the crank. Do the rubber seals (felpro 30135) fit better and get rid of that binding issue?
Any help would be appreciated.
Chris
Chris
