pedal2themetal45
HI ALL
I put a filter between the pump (stock pump) and the tank (next to the pump) and it don't fill up but there seams to be a lot of volume out of the pump to the carb. I know its not normal but do you think Its OK.. When I was first starting it up in the drive way I just used a gas can under the car and the filter would fill up then. the only change is its comming from the tank now... I replaced the only other rubber hose at the tank, the rest of the line is metal,, could it be the in the tank filter/screen? I sealed it up real nice and it don't leak now and I realy don't want to pull the sending unit.. but If I have to??
tim
tim
