rommaster2
Ok well i was reviewing the idiots guide to turbocharging the falcon six and it suggests an adjustable fuel pressure regulator which makes sense to me but I don't know how to select it properly. Basically where i am stuck at is the range that they adjust, most that i saw on summit were between 30-120psi or something like that. Now the reason that confuses me is i see the majority of non adjustables at like 8 psi. Would the adjustable one being that high allow me to use a two barrel NA as well for tuning purposes or would it only work well on the turbo as it would need more fuel pressure.
Also is there anything particular i should watch out for when picking out an electric fuel pump?
