I'm posting this here because it applies to both 6cyl Falcon's and Mustangs, not to 1 or the other, and has to do with the 2bbl mod.
If there is no available donor car, for the cable operated gas pedal. Speedway Motors sells there Problem Saver Pedal P/N 913-55005. this can be easilly mod'd to accept a factory pedal pad from the existing Ford assembly. All you have to do is cut off the spoon, and the part of the pedal that turns outward, drill the appropriate size hole, in the new pedal shaft, use a small bolt, and some washers as spacers, and attach the factory ford pedal pad into the new Problem Saver Pedal. for $40, it comes with a 23" cable, bolts to firewall with 3 bolts, and to cut the auto Kickdown confusion w/ the C4, get a Holley throttle cable bracket w/ auto kickdown cable bracket. lokar sells a kit for a C4 kickdown, the P/N is KD-20C4HT, sells for about $60
