and it keeps going...
finally have some real heat here in AZ... and humidity is 0 every summer... think someone mentioned humidity...
I don't think I'm getting enough air through the radiator. I know I'm transferring heat to the water beautifully and efficiently, but it comes down to the radiator.
the reason I think it's air, outside air is hot right now, but during the winter, my 195* t-stat stayed on 180* for short comutes, longer drives would go to 195* but traffic speeds would put it back to 180, think that's the breather hole leaking the good heat.
when it was cool, my 2400cfm fan did great. but as it is heating up, I toggle my ac off as engine coolant goes to 210*-230* with the AC, sure I can drive without AC, but I have AC cause I want AC!!
at speeds 60+, I'm having a heat issue 230*+ with AC LOW, turn off the fan and the temp climbs in summer/winter winter not much but summer it rockets hot. I won't use High at these speeds.
at speeds 30-55 if stay in 5th gear and give room between cars it's good 210* low AC, high I'll be 230* bad,
0-30mph 210 low, <230 high.
I think it's radiator heat transfer related.
temp gauge is mech, and plugged in the back of the head.
so plans
easy, turn off AC... umm, not an option, I'm spoiling myself here... this is veto'd
manageable, toggle AC compressor, yeah doing this now, not good enough! next...
Simple, by-pass heater core so water flows all the time... no hot spots. see if it 'helps' or fixes, doubt this... but worth a shot, again
body work, replace or modify valence for air dam... I can cut it, if I like it/helps, I can order a real air dam for $150 and have it painted to match.
EXTREME, rip out radiator, cut support for a 24inch cross flow, custom order 351ci alum rad but with i6 inlets, install dual 12inch fan setup and shroud to cover entire area, be able to run AC on high in 115* heat. Figure I'll spend close to $500 on this.
I'm going to go in order, simple first, body work, then extreme... I will stop sweating in summer with my AC on, if it was high I wouldn't sweat but low makes me sweat and AC off well, that's just uncalled for...
