After being asked several times elsewhere, I thought I'd post the science here. For some of you, this is simple, but for newcomers, it's news.
Inside most of the I6 distributors there are 2 advance limiter slots. One is usually larger than the other. The total mechanical advance is TWICE the value that is stamped on the distributor plate. The moving plate that advances has a post that is inserted into one of these slots. Whichever slot contains the post is the one your distributor is using.
Using the larger numbered slot requires less static timing and vice-versa. If your engine has strong compression, using the LARGER numbered slot will allow wider advance angle and less static. This will help starting, especially in cold weather or when the engine has hot-soaked. Using the SMALLER numbered slot will let you run more static advance, which can help generate a "peppy" feeling at lower engine speeds.
Generally, if your carb is aged and the throttle plate is worn, you can get a better idling characteristic by using the LARGER slot and setting less static timing. This is because it will require a larger throttle opening to generate the idle, which allows more adjustment range with the carb.
If most of your engine is in good shape, try using lighter-weight springs in the distributor. Whatever advance curve you're using, it will advance faster and will improve gas mileage, if it does not cause knock.
To change your distributor from one slot to the other (distributor out of the car), remove the plate that supports the points (or pickup, if Duraspark) and then the screw in the center of the shaft. Pull the advance mechanism out of the distributor. Most advance units have a small spring that also needs to be removed to release the advance cam (on points distributors, especially). Then pull off the advance cam, turn it 180 degrees and reinstall in the reverse of the above.
These are general rules, but actually apply to all engines, not just these sixes.
