Go with a holly 350 2 barrel?
I posted a few days ago about having a shot 1100. Think I'm going to swap to a 2 barrel. The car is a 67 Mustang convertible, manual trans, rebuilt 200 engine, hot cam, Clifford dual exhaust header. I have read many posts on this subject.
1) Clifford sells an adapter that solves the height problems with this swap. You remove the old spacer first. It does mount the carb sideways? Does this cause problems? If so, what? Also, it appears that the adapter is set-up for a 67 mustangs linkage. That solves a major problem with the swap.
Here is a link to the adapter:
http://www.cliffordperformance.net/Merc ... _Code=F200
Here is a link to a website comparing adapters: (Very cool site)
http://home.centurytel.net/fordfan/Falc ... rsion.html
Then I need to upgrade the distributer to non scv. Don't have a ton of money...so, can I buy a rebuilt 68 distributor for now? And do one of the other ignition upgrades later? Or is that a complete waste? The car is a weekend driver so I really don't mind points.
Please advise. And thanks a lot!
