First I'll start off with saying Hello.
Hi.
I’m new here and recently I purchased a 1964 Ford Ranchero with the intent of re-building and lightly modifying the engine for the purposes of daily driving and occasionally towing a small trailer and car. (Car weighs less then 2000lbs)
When I originally ran all the numbers for the car on the door plate I was disappointed to find it was a 170 (stock) but after checking the engine it turns out I have a '65 200. Which if just fine with me
The questions I have are purely for the sake of making the engine strong enough for towing with out switching to a V8 and not degrading the normal, every day drive-ability I would like from the engine. (I currently drive a 1966 Sunbeam Alpine with a 1725cc engine that’s about as modified as you can get with out having insane compression)
Dose anyone know how much or how little work I need to do to the exhaust ports to help benefit the breathing with out sacrificing any or very little low end torque?
Do the ridges in the intake log help with fuel atomization, would going though and smoothing out the inside of the log be beneficial or harmful?
Would re-shaping the combustion chambers benefit me in the long run, or would leaving them near stock with adjustments made just to adjust compression be the best way to go?
What would be a good cam option for daily driving / towing on the 200?
Dose anyone know if I would be better off with an Automatic or can a T-5 conversion with a heavy pressure plate / clutch stand up to the demands of towing?
Thanks for any responses?
Alex
			Hi.
Alex
