Got a grand to blow, bang for buck?
Hey all, I have a stock I-6 200 with a K&N filter, I have a grand to blow and would like to kick up the power a bit, at least to a respectable level. My question is what to do? I was thinking a duel header running into a pair of borla's. What size pipe should I use? What all can I do to improve the intake for a reasonable price? Can I go two barrel? What about cams? I know I'm pushin over a grand but some is for future referance. My 200 runs great with 75,000 miles. So if you had my bone stock engine, where would you begin. Also most work will be done by myself and I have enough experience to do a fairly good job. Pipes will be done by a shop because I don't have a welder or good welding skills. Thanks for any replies.
RudyD
In order:
1. Duraspark II
2. Pacemaker headers with Jet-Hot or HPC
3. Single or dual out exhaust
4. Rollmaster timing set
That will likely come close to a G.
hey addo, where would i get a Rollmaster timing set? id like to know cause ive been looking for one. thanks in advance
addo":uvvbfdp1 said:
In order:
1. Duraspark II
Ditto, but keep your pipe size to 2" or less (1 7/8 is about ideal) to maintain good exhaust velocity.
lets see if I had a 200... I`d get a 250
:lol:
what ever carb u get don`t go over 300 cfm
a shift kit
trans cooler
a mild cam
hedder single outlet 2 1/2
79-83 head mill .30
3:00.1 - 3:55.1 gears
deraspark 2
good luck 8)
In order, for a grand I would add:
1. Ignition (pertronix or DII, wires, cap, plugs) $100 - 150
2. Exhaust (headers, duals) $400-600
3. Cam, lifters, timing set, gaskets $300 - 400
4. Chrome valve cover and gasket $25
