I bought the h/w 5200 and thought I was getting the electric choke model. Instead I got the water choke with the electric assist. This may not be a problem, but I do have several questions for you that have this set up..
1) Should I invest in the conversion to make it straight electric? I've seen that several have used a kit from Electro-dyn. What's the cost on this?
2) Should I run it the way it was designed? What are the advantages and disadvatages to each? From the searches I've done, it seems like a matter of preference..
3) Can I run the carb without connecting the water hoses, or will the carb always feel that it is cold and run too rich? I live in Texas and today it's 105F..
Thanks as usual for any help.
