I have a head gasket leak on my 170 with a 75 200 head. The head was milled .055. The block was decked just enough to get it flat. I'm using a composite gasket. Everything looks good, but i have a compression loss between #5 and #6.......Is it possible that I bottomed out the head bolts just enough to reduce the clamping force? I think I should add head bolt washers, does anyone have a good source and maybe a part number? I'd rather find them local if I can. Thanks!
