Head Swapping Newbie
I think I'm just going to have a shop build a plate from 1 inch aluminum plate.I just finished my "drawing" and will be taking it to a local machine shop tomorrow so hopefully I can get it back by Wed.
Greetings All-
Well the Machine Shop took a bit longer than I expected :cry: [2 weeks] to build my carb spacer plate. But they did a great job. I unfortunately had to do a couple of minor mods for linkage clearances though. Tonight I got everything hooked back up, put in the fluids, reconnected the battery, and turned the key.
:D It runs! No leaks, scraping, groaning or other weirdness.Just have to adjust the idle speed and it should be ready to take on a short cruise/ dry run to test. I finished with a flash light in my teeth since I have no real garage to work in. Tomorrow A.M. I'll start it up and check over it again before I take it for a test drive.
-Dave
