heater tube
guys another question got a new exhaust manifold and a heater tube that goes to the carb from exhaust manifold. question how do you put the tube in the manifold . the tube is kinda bigger for the hole , any suggestion... thanks
If you get a universal Choke Tube Kit (from NAPA, etc.) there are two plugs (you only need one) that have a 1/4 inch inside diameter (for the aluminum tube from the carb choke) on one end and about a 1/8 or 3/16th outside diameter tube on the other end that fits into the heat riser/stove pipe hole in the exhaust manifold. You jam the choke tube into the 1/4 inch end and then jam the 1/8 inche smaller end into the heat riser. I can post a pic if you need one but they have these kits at NAPA for 10-12 bucks.
Good Luck-
Marc in SF
63 Comet Ragtop with 69 200 ci/C4 tranny
Dual Cupholders
http://mercurycomet.net
MercuryMarc":1m1d2s7l said:
PS- can you tell me how to paste the image into the text of the posts?
[ img ] url of picture [ /img ] and all of that written close together.
should look like this:
if you´re still unsure, just hit the "quote"-button. Instead of the pic above, you´ll see the complete order for image pasting, or whatever that is called.
