@63 Sprint yeah, it did clear out and adjusted to throttle position with high rpms... I guess I didn't expect it to jump up so much.
So I got carb back in November and already sent that one to Redline and got another one from them. I will contact them again, see what they can suggest. Last time they suggested to put Weber regulator (about $130), but it has the same limitation for inlet pressure.
Yes, that's the one I have 12-804. You are right, I might have too much inlet pressure. Would it be crazy to place another fuel pressure regulator after the pump before this one? Let's say just step up to the next range 4-9psi? I believe there is Holley 12-803 or something similar.
I might also put another fuel pressure gauge after the pump to see what its pushing (couple months ago I wanted to do that, but ended up skipping it).
Or as you suggested before - just install electric fuel pump, which possibly might solve all those issues...
@pmuller9 thank you, will try that as well
@sixtseventwo4d I think it started better on the first video - when I completely removed the PCV and tied it together to stop the vacuum. But I was getting smoke from the open PCV port on the valve cover - not pleasant to breathe in lol
I don't think I can adjust timing until I get it to idle on idle circuit without holding the throttle open.
@DON something like Auxiliary Gas Tank and just hang in and directly connect to the carb (or to the filter before carb)?
Let’s stay focused on the root of the problem.
The PCV is not the root of the problem.
Simple trouble shooting in the order below:
#1– Fuel supply pressure.
#2– Carburetor setup and adjustment.
We just came to the conclusion that cutting off the fuel supply leaned out the engine enough that it cleared out and started running as it should. That is where effort needs to be concentrated on at this time. Not anything else. When fuel supply is corrected or confirmed that it’s not the problem. Then one moves to step #2. Not anything else.
This is exactly what I expected.
I don’t believe that you mentioned that Redline sent you another carburetor. Knowing this would have pointed out that the carburetor might not have been the issue in the beginning.
That is correct.
The one you have should work fine. Do not change it.
No reason to do that. Save your money. Pressure Gauges will show average pressure. Not peaks.
That is correct.
I would try a low pressure “clickity clack” electric fuel pump or, if cost isn’t a huge concern, a Holley 1.5 - 4 psi electric pump and try it right at the mechanical pump taking the inlet and outlet off of the mechanical pump and connecting it to the electric. Of course, you would get the same results on the test by using a fuel tank off of a mower or snowblower.
I would advise to go with a weber fuel pressure regulator. These carbs are so sensitive if pressure isn't set to 1-3 psi.
The WilliingnessLimp already has information on the correct electric pump to use.
WillingnessLimp has a regulator that is compatible for the Weber carburetor. It’s within spec.
I spoke with Redline and mentioned what WillingnessLimp is going through.
They said to have him give them a call.
I will send WillingnessLimp the contact information by PM.
My suggestion was purely if he didn’t want, or is unable to, spend a lot on an electric pump. The “clickity clacks” will get you by in a pinch.
Redline did ask if the floats are brass or plastic. The reason is Weber did not notify Redline of the change. Plastic floats are being damaged by ethanol fuel. Redline informed me that some plastic floats needed to be replaced within a year. Redline does have brass floats as a replacement.
What is going on with today’s manufacturing?
Thanks,
We already discussed which electric fuel pump to use in post #180. It’s getting hard for all of us to remember what has been discussed. But we’re getting there.:)
Willingnesslimp,
I just noticed that you are running a regulator with a pressure gauge before the carburetor. The way it looks is it’s plumbed as a dead head system (without a return line). Such a system will not work with your Weber carburetor that has a mechanical fuel pump.
My recommendation is start with a facet electric fuel pump and keep the regulator as it is.
Here is a fuel pump that should work deadhead with your regulator.
If that doesn’t work, then I would recommend replacing the regulator with one that will allow a return to the tank.
@63 Sprint somewhere in the thread I did say about getting a new carb from them. But I think what threw me off is that I pretty much just put new carb on the same set up I’ve had with the other carb and couldn’t get the car running. The carb I sent them was faulty - throttle blades would not close completely and progression ports were exposed all the time. But car idled (at about 900 rpm) and drove. Nothing close to what I’m experiencing now.
Just in case, I have plastic floats.
@Jmustang_65 yes, they suggested it. But it’s pretty much the same as Holley. And they require the same top inlet pressure of no more than 7 psi
Thanks,
I saw that as I’ve been following this thread. The op may not want to drop $80 on a pump over a hunch and I was pointing out that there are less expensive options. Some as low as $14.00 just to try.
Seems a lot of progress has been made since yesterday. @DON's suggestion of a gravity feed fuel supply is a good one. I would do that. It costs nothing but time and elbow grease.
Note: Make sure that you disconnect the inlet line to your mechanical fuel pump and block that off before you attempt to start the car.
You can simply feed the carb directly from the gravity feed tank, whatever you choose to use. I would use a motorcycle gas tank because I have them but I don't know what normal people would use. I have seen people use plastic pop bottles and small jerry cans. You don't need more than a cup of fuel to test the theory but you also need to do it safely.
EDIT:
@63 Sprint has pushed for electric fuel pumps throughout this thread and in various other ones. Mine has done well in terms of pressure and dependability but I'm putting in an electric this weekend. The fuel we use isn't the same as it was 60 years ago and my fuel pump gets hot after driving on a sunny day for 20 minutes or so. I am certain an electric fuel pump will keep it cooler and my carburetor will provide a more consistent charge.
@vssman thank you for the suggestion! I don’t mind getting a better and reliable fuel pump. But of course, I would rather save some $ - aren’t we all are? ◡̈
@awasson I will try that test over the weekend and see how carb behaves. I guess that will point me in the right direction - either carb problem or my current fuel delivery.
@63 Sprint unfortunately, I can’t do it outdoors…car is in the garage and my entrance is pretty slanted and I’m not sure that I’ll be able to push it back in the garage…. I’ll make sure that there are no leaks for that gravity tank system.
As a thought, I was concidering if I should temporarily mount my stock autolite 1100 and see if the car runs
Yes, at least you can be fairly confident that everything else is working well, aside from the mixture being horribly rich. When you clamped the hose, the engine took right off the way it should have with the throttle cracked like that. It actually sounded really good as it built revs.
@awasson btw, what block off plate will you use for the mechanical fuel pump opening?
And what electric fuel pump are you using?
I might have time during the day on Monday and thinking to use that day for the install (if I end up going with electric), but only Amazon will deliver quick and they have something like Holley Mighty Mite 12-426.
I know 63 Sprint suggested Faucet, I’m just looking at my options
Never mind, I found the exact faucet electric pump on Amazon, but still will take a feedback about Holley might mite if anyone used it
