So what I'm thinking for my next steps:
- open up the carb and check for any debris
- adjust pressure at pressure regulator
- remove the inline filter and replace it with filter at the carb (possibly) OR just run it without it (my fuel pump does have filter already)
- change oil
- switch back to non adjustable rocker arms (to exclude possible problem for now and just deal with carb/fuel delivery)
- check dizzy for good spark on each spark plug
If all that doesn't solve the start up and flooding issues - move on to the electric fuel pump
With the float attached to the airhorn, needle in place, work it by hand with brakeclean and/or compressed air to be SURE a tiny sliver of rubber/metal/debris is not preventing it from seating. I like to flip the assembly over so the float is seated by gravity, then blow into the fuel inlet to be sure the needle is seated and sealed in the seat. If any air can pass with the float closed by gravity, the needle is still dirty or misadjusted.So what I'm thinking for my next steps:
Thanks Andrew! I can get you a plane ticketThat sounds good. You can remove or keep the clear filter it if the pump has a filter.
That is a substantial amount of fuel in your oil to raise the level that much.
I wonder if it would be worthwhile to add a little marvel mystery oil to the bores and manually rotate the crank to make sure there is a light film of oil in the bores. My concern about washing down the bores with gas on a newish build is that it can wear the rings and the hone and prevent the rings from setting.
I think you probably have good spark and I think your rockers are not the issue, although they may have been too tight initially.
It seems the problem is that your carburetor was literally dumping fuel into the cylinders and washing down the bores. My main interest would be to watch the throat of the carburetor when your engine is cranking to make sure that you aren't seeing fuel pouring into the engine.
By the end of this, you will be an expert in troubleshooting these engines. I'm sorry we're about 1200 miles apart or I'd be in the garage giving you a hand.
No! You do not use compressed air on a needle and seat that is meant to operate at 3 psi.With the float attached to the airhorn, needle in place, work it by hand with brakeclean and/or compressed air to be SURE a tiny sliver of rubber/metal/debris is not preventing it from seating. I like to flip the assembly over so the float is seated by gravity, then blow into the fuel inlet to be sure the needle is seated and sealed in the seat. If any air can pass with the float closed by gravity, the needle is still dirty or misadjusted.
