Jmustang_65
I have an 1983 big bell lower starter mount engine block. I got a Modern Driveline billet steel flywheel and when I torque it down, I'm not able to crank the engine by hand. I have to loosen each bolt to just about hand tight to be able to crank it. All Spark plugs are out. Engine was run in an engine stand at it was a new build. Just installing a T5 now.
I have tested:
Regular 7/16-1 inch bolts, Arp 1 inch and .625 inch bolts. I have added 2 washer to the .625 inch bolt to make sure I'm not bottoming out the crank bolts.
The engine spins freely with the flywheel off and with it on but bolts are just hand tight at most.
What can be the issue?
I seen flywheel shims is that an option to use/test?
I have tested:
