I need some help with carb/ignition issues in the DFW area if possible. I've got a 200 in my Bronco that has typically ran fine. Not sure what carb or distro it has either. I'm not tring to makes tons of power with the thing, just want it reliable.
Having said that, I recently installed a Carter YF from a 250 that Kirk gave me. Upon initial installation it seemed to run fine. Maybe a little more power but hard to tell. Well, I asked Kirk to adjust it a little because it was dieseling a little. Not sure what happened but it started running poorly after that, idling erratically, running hot, stalling, and hard to start. Lose of power at all speed to, almost like it had a dead piston. Well, Kirk played with it a little more but it never got better. I went behind him the other day and double checked all the plug wires and such just to make sure. Noticed the bottom of the carb was a little wet, but nothing really jumped out at me. Fired it up and it ran like it used to, wierd. Drove it around for about 20 miles. It ran good at first, pulled strong. But it started acting up later on doing the same thing. It had a bad lug at takeoff, but if I powered through it, it seemed to smooth out.
Kirk says it's because I have a load-a-matic and it can't be run with the YF, and possibly a bad vaccum advance.
Is there anyone up here who would mind taking a few hours to look atwhat I've got and see if we can't work out my problems? I'd be willing to buy you a plate of BBQ and your favorite adult beverage for your time.
