OK gents, my ignition woes continue. As stated prviously, my MSD fried this weekend so I replaced it with a stock Ford module to control the DSII. Strangely enough, it ran pretty crummy for the first few minutes. Then I tweaked the timing a bit figuring the different ignition would require it, then she ran pretty good...for a few days. Then going down the road 2 nights ago, something went wrong. She went from running smooth to sputtering a bit. I thought for sure I had lost another rocker arm cap bolt (happened twice before...same symptoms). I opened up the valve cover last night and other than needing some very minor tweaking to the valve lash, everything seems fine.
Well, after another day of crappy running, I started experimenting with the plugs. I started with pulling them all to inspect. No surprise. They all were sooted up. I'm running really rich, but I know that. So I cleaned them all up and popped them back in. No difference. Well,not true. It's a little better but not nearlt where it needs to be.
Next, I decided to make sure I didn't have a bad plug or wire so I started pulling plug wires with the motor running. It didn't take long. I popped the 1st one off and the motor stumbled badly. I popped the 2nd one off and there was little if any change. All of the rest of the wires resulted in bad stumbling.
OK, so I've got a problem somewhere in the #2 line of things either from the DSII, wire, plug, ...or...
I tried a different wire...no change
I put a new plug in...no change
I cleaned the DSII top terminals off...no change
I even flipped the cap 180deg and checked...same problem so its not the cap
Well kids, what's next? It aint the plug or wire. Could it be a bad terminal on the cap? Everything looks ok there. Could there be something wrong inside the DSII causing just that terminal not to fire right? Could it be something internal to the #2 cylinder keeping that plug from firing?
Thanks as always gang!
