ok i am currently greasey and i was taking my head off, i took the carb off and the valve cover and took off all the head bolts and ever hose i could see. I also unhooked my exhaust at the dounght. But it isnt coming up. a little raidator fluid is leaking out the side between the block and the head now so i assume that seal there has been broken. Should i just pull harder or am i missing something?? please help!!!!
thank you
kevin
thank you
kevin
