PutPut6
Sorry this is long but I want to be as detailed as possible in hopes of figuring this problem out. Ok, I got a problem that's really bugging me. Recently I finished installing sub-frame connectors, export brace, monte carlo bar, aluminum radiator, radiator fan, and moved battery to the trunk. After finishing everything, I tried starting the car and the battery wasn't giving much juice, just clicking, it had been sitting for sometime while I worked on the car so I charged it up and put it back in the car. Got the car to start, drove around to see how things were. At first everything worked fine while driving, then my tach starting moving erraticly as if it wasn't getting enough power. I turned the electric fan off and everything went back to normal. When I turned the fan back on, the lights dimmed and the tach went crazy again. Eventually it got to the point that the lights were dimmed and the tach was erratic regardless of the fan being on or off. With all this going on, the engine ran perfectly fine. On my way back home a guy pulled out in front of me and I accidentally let the clutch out while braking and stalled the car. I tried starting it back up and the battery was nearly dead, lots of clicking but no turning over. After some choice words, I pushed the car home since I was only a minute away from my house. If I recharge the battery, I can get the car to start, but everytime after I turn it off, it wont start again. I had the alternator checked at autozone and they say it's fine. Took the battery back to where I bought it and they said it's fine. I've replaced the voltage regulator before and wouldn't think that was the problem, although I'm going to go pick a new one up anyways tomorrow. Does anyone have any idea what's going on here? My dad's in Korea so I don't have much help here.
Thanks for all your help
Andrew
Andrew
