Yes a piece of cake. especualy the 1b carbs .
When taking it apart be carefull not to lose anyparts... I don't remember where it is but there is a little round ball barren under a screw inside the carb.. watch for it when you turn the carb upsidedown. A carb kit should have an exploded view of the carb. but there purity easy anyway.. there well also be extra parts in the kit so don't worry if you don't use all of the parts.. most kits well service several different carbs so there well be extra parts. Mostly all you well use is gaskets (match it up with the ones you take off) accelator pump, needal and seat, the little ball barren (it well be under a little squair weight, I think it has something to do with the accelator pump not sure).. becarefull of the float not to bend it up, the adjustments are discribed in the kit.
take care
tim
