I know it has been a while but I am close to finally starting my turbo 300 project. My goals are to get a reliable 300RWHP+ out of this beast on full boost. On a regular day I can cut back on boost. My idea is to use 2 toyota ct-26 turbo's (I have them laying around). I know that these turbo's can do 15-16psi steady but beyond that they are pretty useless. I do want to run intercoolers for them too. Basically I will have to convert my truck to EFI for this to work properly as I plan to use megasquirt and the ford EDIS setup to help aid in tuning. I still want to be able to haul heavy loads if needed but mainly this is going to be a street truck.
A big thing is this: should I go for the twin setup or sell them and put money with them and get a good single? Also I know that there has been a lot of people trying different things since I went to the darkside (imports) and I know that there is more info out there on turboing these beasts. But what will it take to get me to my goal of 300 RWHP+?
As of right now I have my stock 300 that came in my 1980 f-150. I stand a pretty good chance of it having the forged internals as it was a HD truck for a utility company. I plan to replace it with an EFI engine (used) for while I do the rebuild. I have the efi engine and it was free from my brother. So I figure just add a low pressure electric fuel pump, cap the A.I.R. crap and slap my manifolds on it and call it good.
Now comes the main questions:
Which head would you use (efi or carb)
Oversized valves? (sbc one?)
stock compression pistons (8:1)?
should the stock clutch hold at that power level?
what size injectors should I be looking at?
what manual transmission will hold that power?
The main thing I am worried about is the last one. I had the "indestructible" Borg Warner T-18 wide ratio in the truck and still fried 3rd and 4th. Now I have a 3spd out of a '70 with a 240 I-6 and it just ain't what I want. I really want a 5 speed manual tranny. I know most of the newer ones will bolt up but I will need to convert to a hydraulic clutch setup.
Any input to this boost addicted, broke, and confused person?
