Hi, Dennis;
This is the first I've heard of increased maintenance. I can't think what that would be, because bike engines have used 30-35 degree intakes and exhausts since the 1980s.
I had to put the PC seals on mine, too - the oil consumption was outrageous with the unbrella types after my rebuild, which was the main reason for re-pulling the head. The intakes on #3 & #4 were so crudded up that the engine had GREAT difficulty starting when hot: they were only opening about .110" around the crud, which was over .400" thick, and shaped like the intake tract!
When I did the first rebuild, I had the guides knurled - bad choice, I guess. This time I had them 'bored & bronzed' with inserts, cut deeper bowls so the springs could be shimmed up a bit, smoothed out the bowls and the combustion chambers, then milled and used the steel head gasket. Much better performance and MPG now. The oil consumption was immediately better, not great.
As it turned out, the distributor cap I had installed after the rebuild was "clocked late" for the last 3 cylinders in the firing order by 2 distributor (4 crank) degrees. It was mis-manufactured. This caused the rings on #3, #4 and #5 to not seat at all. Now they're beginning to show signs of seating and the engine feels smoother and stronger every day. The oil consumption is dropping noticeably every week, too, so I think I'm on the right track.
The only thing I can think of (about the higher maintenance issue) involves the use of hi-pressure valve springs for hi-RPM work. But, at the normal pressures of the stock springs and the typical 4000 RPM range of the log-headed engines, I can't see why high-force springs would even be needed. I only shimmed mine because they have over 200,000 miles on 'em and the seat pressure was borderline low (and I'm too cheap to buy new ones right now
). Since the primary boost in intake flow would be most evident in the 1000-2100 RPM range with these valves, it seems to me to be the ideal setup for daily street use.
