I recently bought one of these for mine. Its a K&N one, which you just re oil every year or so, and they are one of the best performance filters around....
Sy Hollinshead,
Hey, thanks a lot. This K&N looks really nice.Is the hole on the bottom the same size as the mouth of the 1100 carb? What car did you put it on? Cuz I have a 1966 Mustang and im just conserned that the hight might not clear the hood.
It says the height is 2.5 inches, so you will need to check your clearance. I would have thought 2.5 inches would be ok, but mine is fitted to my Econoline, which is obviously totally different.
The stock air cleaner is as much a muffler as it is an air cleaner. At part throttle with an open air cleaner the 1100 sounds like a giant industrial vacuum cleaner!
We are making a drop base for our new oval air cleaner, as well as an adaptor so it fits the 1100 carbs? Both should be ready in a few weeks? Height with the drop base should be around 2 1/2".
For my YF I got a set of air cleaner adapters/spacers from autozone. Theres a pack that contains 2 different adapters and 3 spacers. One from the kit fit my YF with just a little dremel work to clear the choke. The adapter allowed me to slap on a drop base 14" round air cleaner meant for a 4 barrel.
If you want one of the little 4" round air cleaners, I have one but it needs a new filter and the chrome could use a polish. It has a setscrew mount that should work with the 1100. Its yours for $5 + shipping if you want it.
