Holley 1946 Air cleaner adapter?
DarkRose
Does anyone make an air cleaner neck adapter for the Holley 1946? (Not sure of the OD on the carb neck, haven't measured it, but smalle than the standard 2 bbl carb adapters)
Just looking to have some more air cleaner options, such as the Classic Inline lo-pro carb hat...
Thanks! I didn't find any currently, but saw a couple ended auctions on Ebay that gave me a couple idea from just seeing them...
This Fox shell item is a really odd item to form because its like a boiler lid or mushroom underneath.
The air cleaner and general sizes are okay for the X-shell bodies with 200 engines, the 250 uses another type.
It's got space for other 1-bbl Ford carbs like the YB Carter and F150 truck and CFI HSC 2.3 OHV 1-bbl injection set-ups.
Six other options to raid an air cleaner
1.Owner fabrication required till there is a special replacement.
I'm sure there must be a 22 dollar special since this carb is used on
2. AMC 232 and 258's's,
3. Mopar 225 Slant Sixes
4. The 2.0/2.3 OHC Limas, (post 1985 on Rangers, and Mustangs and other Fox bodies with the corporate four banger)
5. the Tempo/Topaz Holley 1949 US 2.3L HSC cars in 1984 only, and
6. the Canadian Tempo/Topaz 2.3L HSC engines from 1984 until 1987 (Holley 1949) .
The Mopar model was Holley 1945 for the slant, and it might have had a few fix differences without the cross over bracket, but you'd get the right size air cleaner from one of those, no "from scratch" building.
See http://u225.torque.net/cars/SL6/docs/Holley_1945.pdf
The 75-79 AMC Gremlin had the Holley 1946 Carb, and it was
1975-1976 AMC Gremlin 3.8 L 232 CID L6
1975 - 1976 AMC Gremlin 4.2 L 258 CID L6
1975 - 1976 AMC Hornet 3.8 L 232 CID L6
1975 - 1976 AMC Hornet4.2 L 258 CID L6
1975 - 1976 AMC Matador4.2 L 258 CID L6
1975 - 1976 AMC Pacer3.8 L 232 CID L6
1975 - 1976 AMC Pacer4.2 L 258 CID L61
The 1946 and 1949 1-bbl was used on Ford 4 and 6 cylinder engines into the 1980's, and on industrial applications well into the 1990's. The 6145 and 6159 was a computer controlled, feedback version used in 1985 Ford 4 cylinder cars, so the Rangers with 2.0, 2.3 1-bbls, and Fox body LTDs or Mustangs with 2.3 1--bls from 1984 onwards should have a good air cleaner. The HSC Tempo Topaz with the 1949 1-bbl, that could be a donar . See how similar it is to the 1946 in this item on 1949/6149 see http://autorepair.about.com/library/faqs/bl640b.htm
But from Linc's200, he had this
Another pass side shot:
it bolted to this
According to this link, http://www.albertpenello.com/mustang/engine.html use the stock 1965 air cleaner with the 1946 and later model head. But it lookes to me like its a Holley 1940 carb, and he's possibly made an error. Do try the stock air cleaner, though, it just might work.
Sorry I didn't understand this untill recently, though I've always had access to it since 2003.
