embergloP51
Active member
So, I decided I wanted to install a Holley 5200 on an adapter on my 66 200 I6. I was wondering if the weber carb adapter for a small log would the be the right one to use since the holley 5200 is a copy of the weber 32/26? Also, will the weber 32/36 air cleaners fit? I assume I'd have to go with the lower profile one since the carb will be on an adapter?
And finally, is there a particular submodel of 5200 I should look for or will any of them work fine? Meaning, if I have a list of part numbers to choose from, which is best? I would prefer an electric choke model.
