Looks like Fuel Injector Clinic’s smallest injector is the 42lbs injector. Question now is if this injector is too big to use naturally aspirated until I do the turbo later down the road? FIC is super trustworthy and they say they have great short pulse width control so hopefully it’ll be ok. I’ll wait for pmuller9 or someone else who’s knowledgeable to answer before purchasing. I learned my lesson impulse buying when pmuller9 yelled at me for buying the wrong cam lol.
As the injector gets larger, the short pulse width required for idle and cruise gets closer to the non-linear response region of the injector.
This makes the control of the fuel at very low engine loads more difficult.
It looks like the Fuel Injector Clinic's fuel injectors are advertised as having "Superior short pulse width control" which is good.
The 42 lb injectors will let you generate around 375 hp with a turbocharger in the future.
About the camshaft you ordered.
The Ford 4.9 EFI engine is detonation prone and works better if the camshaft has a long advertised intake duration.
The Melling MTF-6 has a long advertised duration of 280 degrees which works.
Secondly there are no cam cores available to grind a turbo friendly camshaft profile even if I could recommend one.
The intake lobe on the Melling MTF-6 is perfect.
All you would need to do is to have the exhaust lobes reground to 204 degrees of .050" duration and increase the Lobe Separation Angle from 110 to 112 degrees if possible.
This would give you a good low to midrange high torque power band with a turbocharger.
I didn't yell at you. I calmed myself down first, took a chill pill and walked around the block for 15 minutes before replying.
Then I calmly asked what the reason was behind your decision to buy that cam.
LOL.
