All Small Six Hot Lash?
wakjob
Supporter 2020
Any need or reason to do this on a 200cid with adjustable rockers?
Or is the initial shop manual set up procedure enough?
Shop Manual makes no mention of doing a hot lash on the inlines...only the V8's.
This article has me confused...
Thanks Bill...
The hydraulic lifter needs to be completely collapsed (like new)...correct?
When I initially built the engine with new lifters (not soaked or pumped up), I did the up & down wiggle test with the rods, then added a 1/4 turn on the adjuster...locked them down. And basically followed the method you listed above.
This hot lash procedure just seems unnecessary.
Plus, I think you'd need that lifter bleed tool to compress the lifter.
Thanks Bill...
No the plunger in the lifter should be at the top, not collapsed, but pumped up.
